Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
After installing a Replica File Server and registering it with the Master, when I try to add a Host to the Replica site, using the File Server Administrator/Vault Configuration, I get the following error;
I have a call into PTC support but all they had me do was remove a couple of rows from the fvhost table in oracle. This did not fix the issue. I can successfully run the Broadcast Configuration. Any ideas?
