Installing Windchill 12.1.1. I'm trying to use the Mssql database, but I get that error even though all of the above information is correct. I want to know why. If you select New Database and enter the above information, there is no problem.
Hello @WS_10272479
Share this file PTCSOLNINSTALLER_PtcInstall.log under %TEMP% folder with me
Found the same error, refer to https://www.ptc.com/en/support/article/CS372889
As a result of executing the supplied command, 1> is returned normally. The PTCSOLNINSTALLER_PtcInstall.log file was not created.
