Problems occurred while installing Windchill 12.1.1 using Mssql
  • October 30, 2023
  • 1492 views
Installing Windchill 12.1.1. I'm trying to use the Mssql database, but I get that error even though all of the above information is correct. I want to know why. If you select New Database and enter the above information, there is no problem.
Hello @WS_10272479
Share this file PTCSOLNINSTALLER_PtcInstall.log under %TEMP% folder with me
Found the same error, refer to https://www.ptc.com/en/support/article/CS372889
  • Steps listed in Article CS28197 can be followed to manually create an SQL Database
  • As a troubleshooting step one can use:
    • sqlcmd.exe -S ServerName\InstanceName,Portnumber -U dbUserName -P dbPassword  -d Database
    • if successful a 1> prompt is returned
    • if error, those needs to be fixed prior executing PSI
  • Note: make sure to download the correct Java version that is supported for you Windchill server refer to the Software Matrices for more details
As a result of executing the supplied command, 1> is returned normally. The PTCSOLNINSTALLER_PtcInstall.log file was not created.
Hi @WS_10272479
Suggest create a case for TS investigation
