We are setting up a simple workflow in a context that is used for testing and Reporting, All the objects will be Word documents.
The business process is : The document is created and checked in and then promoted to the next state for review and approval ( to a specific person), then he approves/rejects and then promotes it to the next state for a review and approval ( two specific people, could be a role) they both must approve it and then do the same , Promote for the final signiture and then the obejct gets released.
We have this set up now to have the user change states - We are looking for the approval process/Sign off that the promotion request gives us.
Hi
it must be a balance between current business processes and implementing a new technology.
We can't implement a new technology without reviewing current processes as certain steps could be made obsolete per the new technology, You can't simply change a business process only because a new technology cannot handle something, otherwise you may end up out of business.
It is like when getting married. Business Processes and Technology must live happy together and therefore changes in both must be required.
The promotion process Steve mentioned also include an OOTB review process. You can also duplicate this process, modify it to add gates and apply it in your OIR but I always try to make users understand that it is not because they have done something for the last 20 years (with no issue what so ever) that it is still the best way to do things.
Adoption is important but adaptation is as important
Good luck
Best regards
