Pulling User Attributes from Active Directory into Windchill
CS_9737528
We are looking to pulling/integrate additional attributes (job title, department, and company) from Active Directory into Windchill user attributes.  We have tried to map these attributes in the Info*Engine JNDI Adapter, but have had no luck getting the data into Windchill.  We are on version 11.1 M020 CPS16.
We also tried to follow CS162357 without any luck as well.
Craig
TomU
(To:CS_9737528)
CS_9737528
(To:TomU)
I believe this is a product issue.  Support was able to replicate my issue, and they also cannot get the non standard field information to pull into Windchill from Active Directory.
Craig
TomU
(To:CS_9737528)
Let us know where it ultimately ends up.  Thanks.
CS_9737528
(To:TomU)
Is there a way to manually update a user attribute while SSO is turned on?  If not, is it possible to turn off SSO, update the user attributes and then turn it back on?
Craig
