Version: Windchill 11.2
Use Case:
Currently, I am using the CPS22 version bundle for the installation process.
My test computer has never had any WindChill installed.
The path is set to D:\WindchillInstall.
The folder paths are as follows:
ownload URL: https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=WPD
I have tried downloading the following files and placing them in the specified path:
However, the installation process still cannot find the files.
Has anyone else experienced a similar issue?
Could it be due to a language translation problem, or is there something I am doing wrong?
Description:
PTC hasn't removed Windchill 11.0 from their software downloads yet. It is the second one.
If the 11.0 Multi-Language Pack is not available to you from the PTC website, then you need to log a call with PTC to get access to it.
Also, remove all other Multi-Language packs from your software staging area in case the installer defaults to the latest available during installation.
The list of downloads you provided in the description are for 12.0, 13.0, and 13.1. When installing 11.0, you need the 11.0 Multi-Language Pack that matches the version requested by the PSI Installer "M030-CPS18".
HI Sir
Could you please tell me which option I should click to download?
I have tried downloading all versions of the Multi-Language Pack from the download page and putting them in my installation path, but the problem still occurs.
So, I ended up using CPS17 for the installation instead of CPS22, and it worked! 🎉
I did install the language pack path you mentioned, but sadly, it still won't install properly. Thanks a lot for your help
