Hi.
I'm trying to find out how to change the image at the top of the Windchill UI. I need to "rebrand" the header in Windchill to match my user community colors and images. I did this in our V9.1 environment, but haven't found out how to do this in V10.2 yet. Also, I would like to customize the colors used by the browser.
Not the right shade of blue for our customers. Something like this:
Anyone have an idea where I need to look?
Take a look at Customizing UI Branding.
Something else you can do is manually alter the colors in some key files. (You won't find this in the documentation.) Here is a picture of what my test system looks like and the files I changed to get there. (This is for 10.2)
codebase\netmarkets\themes\windchill\Header\
codebase\netmarkets\themes\windchill\navigator\
codebase\netmarkets\themes\windchill\panel\
Looks like the images didn't come out.
Hey Tom,
How did you get the "Windchill Test System" to come up? I have looked at the files you posted and they don't pertain to this text on your pic.
Thanks in advance,
Buddy Hudson
Sorry about that. The concept is covered in "System Banner Alert Message".
Basically you add a single line to begin_custom.jspf and then put something in banner.txt.
My banner.txt file contains the following:
<style>
#bannerID{
font-size:15px;
cursor:default;
float:left;
clear:both;
position:absolute;
margin:2px 170px;
padding:3px;
top:0px;
z-index:1000;
</style>
<span id="bannerID">
<!-- Banner begins here -->
<b><a style="color:#FFFFFF">Windchill 10.2 Test System</a></b>
<!-- Banner ends here -->
</span>
<script type="text/javascript">
//START--The tooltip for the top banner
Ext.onReady(function(){
Ext.QuickTips.init();
new Ext.ToolTip({
target: 'bannerID',
html: '10.2 M010 Test (05/23/2014)'
//END--The tooltip for the top banner
</script>
Awesome! Works great thanks again Tom!
Buddy
Hey Tom,
This is an excellent example and a really good looking windchill.
Thanks for providing that!!
Tom Uminn, do you find that the background of the navigator is still blue when you expand it? I have a screenshot below.
FYI...I really like your method. Grab these files and just open in IrfanView. Select Image > Swap > and then one of the options there. The dark pink is RGB -> GBR. Very simple but very effective.
Here is the list of the folders and files I'm changing:
Header
navigator
panel
I automatically replace these after each rehost with these commands:
copy /y E:\Stage\Dev_Changes\Header\*.* E:\ptc\Windchill_10.2\Windchill\codebase\netmarkets\themes\windchill\Header\*.*
copy /y E:\Stage\Dev_Changes\navigator\*.* E:\ptc\Windchill_10.2\Windchill\codebase\netmarkets\themes\windchill\navigator\*.*
copy /y E:\Stage\Dev_Changes\panel\*.* E:\ptc\Windchill_10.2\Windchill\codebase\netmarkets\themes\windchill\panel\*.*
Ah, I see! BG_stripe_tile_nav.png I actually can't swap RGB with that one, presumably because it is so small. 4px x 4px. Not in IrfanView anyway.
I vaguely remember having to change a couple of them in paint. Looks like maybe all of the panel *tile* images.
I had not until 15 minutes ago. 😉
Windchill 11.0 doesn't use images for the background so changing it is actually easier. Just alter a few values in the main css file: <Windchill Home>\codebase\netmarkets\themes\windchill\xtheme-windchill.css
For example, try changing the background colors on lines 3188, 3193, and 3288 to #FFFF00 (yellow):
Changing these three values will make Windchill look like this:
Thank you Tom!
I changed the background color on line 3188 to a dark blue (#0000FF).
When I open Windchill in Bing, it did not change the color, but in IE and Chrome it did.
Bing is a search engine... Do you mean Microsoft Edge? My guess is that the CSS is cached. Try reloading the page while pressing F5, CTRL + F5, SHIFT + F5, etc.
Yes Edge!
Ctrl-F5 did it.
