There are different reference types in Windchill database. Where I can get more information about these? Like what are they and how are they used.
Please refer attached screenshot. Your response is greatly appreciated.
Thank you.
I suggest that you learn about the references in the application first and then move to the DB. By this you get to know the most important references that are used actually in the application.
Here is the help center.
If you start from DB, you will not be able to understand the application.
All the best
Hari
