I am working with a Setup Participants task. I have three roles that the assignee will need to select a principle to act. The Resource Pool points to a group for each role. Two of the roles use the same resource pool.
I am looking to check three conditions on the transition:
1. That each role has a principle assigned
2.That only one principal has been selected for each role.
3. That the selected participant for the two roles that share a common resource pool do not have the same principle selected.
I have seen some code in other posts that are close to item 1 but not the others. All help is appreciated as I am new to code writting and workflow design.
-Kelly Lozier
BMPC-KAPL
