i need to create a report that selects only the top 50 rows of a report.
I couldn´t find a statement equals to the "SELECT TOP" SQL.
Could anyone explain how i an do that in the query builder?
Greetings!
I haven't found any solution to do so in query builder.
The SQL option TOP is missed from the builder UI in a select.
as @MikeLockwood mentioned. you can only set the limit of tables
PetrH
This is a good question.
Query builder returns 2000 values by default, then waits for the user to select Next if desired.
That's due to this preference - which every user can set to desired value.
Don't see a way to override this preference for a specific report, but possibly others will know how to do so using a custom input.
Or, possibly there is a way to programmatically change this preference value every time the report is run, then change it back.
Or... possibly the report can be save, then a data monitor set up and that data monitor run daily but as a dummy user who has this preference set to 50.
PetrH
