Version: Windchill 12.1
Use Case: Hi, Is it possible to restore the welcome screen shown in the screen shot, After a user checked the red marked box? I could not find any helpful article to reset it. There is no such a thing the preference management of the user. Is it possible to delete a cache or something for a particular user? I have admin credentials too.. This request is not urgent for sure, but one of the users asked me to help him with it.. Thanks for your help
Description:
The checkbox was removed after version 11.
https://www.ptc.com/en/support/article/CS292318
It looks like they purposely removed it. Steps from @mmeadows-3 might be more than you are looking for but if the user wants to see it, he correctly shows where it is in the QuickLinks. I am not sure you want to customize this to enable for all.
Probably more than you care to know about the Welcome page...
https://www.ptc.com/en/support/article/CS194286
%wt_home%\codebase\netmarkets\jsp\netmarkets\welcome.jsp
Notes:
https://www.ptc.com/en/support/article/CS58708
https://www.ptc.com/en/support/article/CS67176
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE NmLoader SYSTEM "standardX20.dtd">
<NmLoader>
<csvPreferenceInstance handler="wt.preference.LoadPreference.createPreferenceInstance">
<csvname>CloseWelcomePage</csvname>
<csvclientName>WINDCHILL</csvclientName>
<csvvalue>b%3A0</csvvalue>
<csvlock>true</csvlock>
</csvPreferenceInstance>
</NmLoader>
Where csvvalue:
windchill wt.load.LoadFromFile -d filename.xml
Thank you so much for your kind research! That helped.
