Restoring the Windchill Welcome Screen - Is it possible?
MR_10810161
Version: Windchill 12.1
Use Case: Hi, Is it possible to restore the welcome screen shown in the screen shot, After a user checked the red marked box? I could not find any helpful article to reset it. There is no such a thing the preference management of the user. Is it possible to delete a cache or something for a particular user? I have admin credentials too.. This request is not urgent for sure, but one of the users asked me to help him with it.. Thanks for your help
Description:
The checkbox was removed after version 11.
https://www.ptc.com/en/support/article/CS292318
It looks like they purposely removed it. Steps from @mmeadows-3 might be more than you are looking for but if the user wants to see it, he correctly shows where it is in the QuickLinks. I am not sure you want to customize this to enable for all.
Probably more than you care to know about the Welcome page...
https://www.ptc.com/en/support/article/CS194286
%wt_home%\codebase\netmarkets\jsp\netmarkets\welcome.jsp
Notes:
  • This page (and the check box) can be accessed by: QuickLinks > Help > Welcome to Windchill
  • %wt_home%\codebase\netmarkets\jsp\netmarkets\welcomepage.jsp is for earlier releases.
https://www.ptc.com/en/support/article/CS58708
  • The page can be turned off for everyone using loadFromFile.
https://www.ptc.com/en/support/article/CS67176
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE NmLoader SYSTEM "standardX20.dtd">
<NmLoader>
<csvPreferenceInstance handler="wt.preference.LoadPreference.createPreferenceInstance">
             <csvname>CloseWelcomePage</csvname>
             <csvclientName>WINDCHILL</csvclientName>
             <csvvalue>b%3A0</csvvalue>
             <csvlock>true</csvlock>
</csvPreferenceInstance>
</NmLoader>
Where csvvalue:
  1. b%3A0 - The Welcome Page is displayed for every user.
  2. b%3A1 - The Welcome Page is not displayed at all.
windchill wt.load.LoadFromFile -d filename.xml
  • The preference can be deleted too.
https://www.ptc.com/en/support/article/CS258377
Thank you so much for your kind research! That helped.
