I've gone done a serious rabbit hole but failing to see my error. I am assuming it must be me. I have two instances and both experience same behavior. I can start and stop SOLR normally as my non-root user. But when I configure my solr.service (which is identical to my previous installs), it fails to see that solr is running, exits and stops the process. I can verify that SOLR does indeed start but the part of the solr script (called from Index_Search_Server.sh) where it checks that SOLR is running, I think is not detecting it. It times out after 180 seconds and stops.
Here is what I observed:
I zeroed in on lsof since that is what I saw running and a while loop in the script. I gather that Index_Search_Server is calling solr but not getting a successful return. I even dug into the github for solr trying to see when this script change (here it is if you are curious https://github.com/apache/solr/commit/3ed17c2737d )
Here is the section where its stuck
# no lsof on cygwin though
if lsof -v 2>&1 | grep -q revision; then
echo -n "Waiting up to $SOLR_START_WAIT seconds to see Solr running on port $SOLR_PORT"
# Launch in a subshell to show the spinner
(loops=0
while true
do
running=$(lsof -t -PniTCP:$SOLR_PORT -sTCP:LISTEN || :)
if [ -z "${running:-}" ]; then
slept=$((loops * 2))
if [ $slept -lt $SOLR_START_WAIT ]; then
sleep 2
loops=$((loops+1))
else
echo -e "Still not seeing Solr listening on $SOLR_PORT after $SOLR_START_WAIT seconds!"
tail -30 "$SOLR_LOGS_DIR/solr.log"
exit # subshell!
fi
else
SOLR_PID=$(ps auxww | grep start\.jar | awk "/\-Djetty\.port=$SOLR_PORT/"' {print $2}' | sort -r)
echo -e "\nStarted Solr server on port $SOLR_PORT (pid=$SOLR_PID). Happy searching!\n"
exit # subshell!
fi
done) &
spinner $!
else
echo -e "NOTE: Please install lsof as this script needs it to determine if Solr is listening on port $SOLR_PORT."
sleep 10
return;
fi
fi
what's tough is I do not see any of these echo statements anywhere when you start as service so not sure what it saying or seeing. This is top after I start solr. You can see java process which is solr and lsof of script trying to determine its running.
Here is info on that process showing it was running with -v option. Odd since that runs normally and
This runs normally and I get output:
Totally stumped here.
Is it possible for you to post the contents of your solr.service file?
[Unit]
Description=Windchill Solr Index Search
After=network.target
[Service]
Type=forking
RemainAfterExit=no
PIDFile=<mypath>/SolrServer/solr/bin/solr-8085.pid
ExecStart=<mypath>/SolrServer/bin/Index_Search_Server.sh start
ExecReload=<mypath>/SolrServer/bin/Index_Search_Server.sh stop
ExecReload=<mypath>/SolrServer/bin/Index_Search_Server.sh start
ExecStop=<mypath>/SolrServer/bin/Index_Search_Server.sh stop
User=<username>
Group=<group>
PrivateTmp=True
LimitNOFILE=infinity
[Install]
WantedBy=multi-user.target
I removed some personal details. Thanks for reply.
