SW WGM Multiple Releases
Dan_Harlan
PDMLink 10.1 M010
When using the workgroup manager for SolidWorks, it only allows you to
have one version of SW registered at a time. We have a need to support
multiple versions in order to support multiple customers. Has anyone
else faced this? Solved it?
Approaches I'm thinking of;
- Batch files to either use command line or configuration file
swap prior to launching the WGM.
- Customizing the WGM to remove the check/lock that prevents
registering more than one.
Biggest concern I have, do I have to worry about corruption? Do I have
to figure out a way to force different workspaces and wt caches?
TIA, will post solution if found.
Dan Harlan
Mechanical Engineer / CAD Administrator
480.940.0036 x178 Office
480.940.0039 Facsimile
481 N. Dean Avenue
Chandler, AZ 85226
dharlan@aitint.com <">mailto:dharlan@aitint.com>
www.aitint.com <">http://www.aitint.com>
Attention Disclaimer: This e-mail and its attachments are privileged and confidential and are the exclusive property of Advanced Integration Technologies, and are intended solely for the use of the individual or entity to whom this e-mail is addressed. Do not copy, use, or distribute this e-mail or its attachments without the consent of Advanced Integration Technologies. If you are not the intended recipient please delete the message and notify the sender. If you are not the intended recipient, you are hereby notified that you may not derive any rights from the information contained herein; and any use, dissemination, or reproduction is strictly prohibited and may be unlawful. Any other use, retention, dissemination, forwarding, printing or copying of this e-mail is strictly prohibited.
Batch file that uses entirely different set of caches should do it. You will need separate batch files for launching the WGM initially for setup as well.
[cid:image002.gif@01CDE8E0.A255E930]
Steve Vinyard
Application Engineer
Steve is correct. We use SW 2011 thru 2013. The tricky part is getting the users to use the correct batch file for the correct version of SW.
Mike Pinkney
CAD Administrator
Triple Ring Tech. Inc.
