How can i search for multiple items? I have two part numbers that yield results when searched for separately but when I use a semicolon or "or" nothing comes up. I've multiple variations with spaces and without? What am I missing or is this not possible?
What I am really after is adding a bunch of items to my workspace at the same time from a list I have. If there is a better way to do that I am open to suggestions.
Hi @ZC_10909252
If your system use a solr index search then you can use the semicolon only in the specific attribute filed, not in the key word column.
@Fadel has showed nice example how it works.
PetrH
I do this all the time in Excel. Say I have a list of numbers to search on using that semicolon trick. In the next column over, use "=CONCAT(B2,";",A3)". Fill that formula down and copy the last entry which will be a merging of all the numbers. You can vary by including a * for a wildcard. I've seen this work with 50 parts but there is some limit to how long this can be.
Hi @ZC_10909252,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Anurag
If you are using the keyword search with Solr (Windchill Index Search), then you need to switch your search mode preference from 'Simple' to 'Advanced' first.
Once you make that change, the keyword search behavior changes. You can tell by the extra text underneath it.
See this page in the help documentation for an explanation of the different options for advanced searching.
Based on this statement from that page, a single space character should automatically be treated as 'OR'. You can also use a comma with a space after it or the word 'OR' with a space before and after it.
