Version: Windchill 12.0
Use Case: The object with the following key was deleted or inaccessible: "wt.part.WTPart:21931276672"
Description:
Article - "Check-in part fails with "The object with the following key was deleted or inaccessible: "wt.epm.EPMDocument:12345" in Windchill PDMLink": https://www.ptc.com/en/support/article/CS131389
Hi @Sandy7 ,
I wanted to see if @VladimirN 's reply helped. If so, please mark it as the Accepted Solution. It will help other members who may have the same question.
