Just installed Windchill/Intralink 10 and right after the install completed I was able to launch andlogin to the interface.
I was able to stop, start & re-login to windchill with no issue.
I reboot, and try to start Apache, Tomcat and Windchill but have been unsucessfull, the MethodServer launches but after a few seconds closes out.
The log files that I found don't seem to provide any info that helps.
Thanks in advance,
Bob
Not sure I have ever started the DS
When testing 9.1 I use to use the following:
enter: start C:\PTC\Intralink\Apache\bin\httpd.exe
enter: C:\PTC\Intralink\Tomcat\bin\wttomcat_start.bat (text will scroll with final text being “INFO: Server startup in 13516 ms)
From shell enter: windchill start
Checked and TNSListener was started
When I was testing 9.1 awhile back I was also checking that Aphelion Administration, Drive Mapping and Services were starting as windows services. When I look at windows services I don't see them even listed
May I trouble someone to paste the actually steps I need to execute after a reboot to have it launch successfully. I must be missing something?
For instance I don’t see anything in chapter 25 page 407 of the Windchill Installation & Configuration Guide on how to start the DataServer or Tomcat
I first want to manually start everything and then later I’ll try and automate it.
Thanks in advance,
Bob
