Unable to restart Windchill
proe.bob
Just installed Windchill/Intralink 10 and right after the install completed I was able to launch andlogin to the interface.
I was able to stop, start & re-login to windchill with no issue.
I reboot, and try to start Apache, Tomcat and Windchill but have been unsucessfull, the MethodServer launches but after a few seconds closes out.
The log files that I found don't seem to provide any info that helps.
Thanks in advance,
Bob
13 REPLIES 13
jessh
(To:proe.bob)
Did you forget to start WindchillDS first?
jtjohnson
(To:proe.bob)
Chances are (if you are using Oracle) that you TNS Liatener is not started.
Not sure I have ever started the DS
When testing 9.1 I use to use the following:
enter: start C:\PTC\Intralink\Apache\bin\httpd.exe
enter: C:\PTC\Intralink\Tomcat\bin\wttomcat_start.bat (text will scroll with final text being “INFO: Server startup in 13516 ms)
From shell enter: windchill start
Without starting WindchillDS, the windchill Methodserver will just freak out and dies as you described. I think you should check to make sure all your services are started windchillDS, Apache, tomcat, Methodsever and oracle.
Alexius C. Chukwuka
IT Analyst, Global SAP Basis
Technical Change Management (TCM)
Deere & Company World Headquarters
400 19th St, Moline, IL 61265
Office: (309) 765-3133
Mobile: (319) 429-5336
Checked and TNSListener was started
When I was testing 9.1 awhile back I was also checking that Aphelion Administration, Drive Mapping and Services were starting as windows services. When I look at windows services I don't see them even listed
BenLoosli
(To:proe.bob)
Aphelion has been replaced with WindchillDS for 10.
It must be started before anything else.
You should install all of the Windchill programs as Autostart services.
Thank you,
Ben H. Loosli
USEC, INC.
Bob,
Before starting the windchill just check if Database and
Aphelion/WindchillDS are up and running, Then go for Apache, Tomcat (Which
is in MS from Windchill 10) and Windchill Server.
If there is still an issue paste the Log file here .
Hope this helps.
Mayur
jessh
(To:proe.bob)
Aphelion isn't used in R10 -- WindchillDS is.
WindchillDS is not installed as a Windows service automatically / by
default.
Jess is correct. WindchillDS is the replacement for Aphelion in Windchill 10. If you are running aphelion with windchill 10, chances are that it probably isn't going to work and your installation was not done correctly.
Alexius C. Chukwuka
Hello Jess/ Alexius ,
With respect to the dicussion below, shouldn't the intsallation check list
check this ?
Also i was refereing Aphelion with respect to the LDAP Server.
Mayur
On Wed, Feb 15, 2012 at 10:10 PM, Chukwuka Alexius C <
> that it probably isn’t going to work and your installation was not done
> correctly.****
> Thanks****
> *Alexius C. Chukwuka*****
> *IT Analyst, Global SAP Basis *
> *Technical Change Management (TCM)*****
> Deere & Company World Headquarters****
> 400 19th St, Moline, IL 61265****
> Office: (309) 765-3133****
> Mobile: (319) 429-5336****
jessh
(To:proe.bob)
I'd *guess* you've got WindchillDS installed, but didn't start it.
May I trouble someone to paste the actually steps I need to execute after a reboot to have it launch successfully. I must be missing something?
For instance I don’t see anything in chapter 25 page 407 of the Windchill Installation & Configuration Guide on how to start the DataServer or Tomcat
I first want to manually start everything and then later I’ll try and automate it.
Thanks in advance,
Bob
Bob,
For Windows it is :-
Navigate to <windchillds>\server\bat. Double-click the control panel command
For additional information please check the Guide at
