Unable to see ChangeActivity in ChangeNotice after migration.
DKWc
Hi All,
Currently have migrated changeorder, changeactivity and changerecord. Along with this used table IncludedIn2 and CHANGERECORD2__761153863 for links.
All loading turned to be successfull.
Able to see CN in UI of WC however, unable to see CA for that CN.
Is there something missing to be done?
Thanks in advance
6 REPLIES 6
avillanueva
23-Emerald I
(To:DKWc)
What was the method you used to migrate this records in? Can you explain and provide examples?
DKWc
(To:avillanueva)
Using WBM
avillanueva
23-Emerald I
(To:DKWc)
IncludedIn2 is the right table that links Change Notice to Change Activity. You should check that BRANCHIDA3A5 matches your change notice Branch id and same for BRANCHIDA3B5 matches branch id for Change Activity.
ChangeRecord2 links resulting items to the Change Activity. It should look like below.
DKWc
(To:avillanueva)
Thanks for the reply. Everything is matching.
Both the object are present in WC and searchable in UI. IncludedIn2 table is also matching.
Able to navigate from change task to change notice, however if look in implementation tab in Change notice, then change task is not visible.
HelesicPetr
(To:DKWc)
Hi @DKWc
What Windchill version do you use?
Windchill 12+ has a Change link business rules . Check the rules if the system is correctly configured or not.
Also check if the rules are not disabled
PetrH
DKWc
(To:HelesicPetr)
Hey Hi,
Good point this area completely slipped.
Checked for it nothing is disabled.
