Did you start Apache and Tomcat?
I just recently did this myself. Some of the possible problems that were "getting in the way" was the fact that WC was configured to run as a windows service and configured for HTTPS. Once I removed HTTPS and ran WC manually the script file completed with no errors. I cannot say this will solve your problem but it did for me two weeks ago.
Steve
I would agree with Steve,
If you cannot use this simple command in a windchill shell you have an issue with authentication. It's probably trying to load data into the system:
