User was able to check out released objects modify them and check it in again, before we went to Windchill 10.2
troßmayer
We went from Windchill 10.0 to 10.2
6 REPLIES 6
BenLoosli
(To:troßmayer)
Sounds like permissions were tightened or changed between 10.0 and 10.2.
Check the ACLs for released data. In my setup, a normal user can NOT check out, modify and check in released files, only an admin can.
troßmayer
(To:BenLoosli)
Its not a normal user, its the responsible designer with supervisor rights.
I checked the ACL
Which right is missing?
Was there a change between the 10.0 and 10.2?
You can set Deny permission on Modify for WTPart, WTDocument and EPMDocument in Released  state for All users
troßmayer
(To:SergeyEfimov)
We are working only with documents. If I set the Released for All user, is this than for supervisors, designers....
I need this only for supervisors, how can i set this?
The best way make it for all
troßmayer
(To:SergeyEfimov)
Strange the user has the modify permission in ALL state´s.
Do I need Modify Content also?
