We went from Windchill 10.0 to 10.2
Sounds like permissions were tightened or changed between 10.0 and 10.2.
Check the ACLs for released data. In my setup, a normal user can NOT check out, modify and check in released files, only an admin can.
Its not a normal user, its the responsible designer with supervisor rights.
I checked the ACL
Which right is missing?
Was there a change between the 10.0 and 10.2?
You can set Deny permission on Modify for WTPart, WTDocument and EPMDocument in Released state for All users
We are working only with documents. If I set the Released for All user, is this than for supervisors, designers....
I need this only for supervisors, how can i set this?
The best way make it for all
Strange the user has the modify permission in ALL state´s.
Do I need Modify Content also?
