New for 10.x is the site-level View and Print Only Group. This Group has one ACL against it at Site level- it denies all actions except Read and Download. At Site, License Reporting, there is a tab for this group.
We recently attempted to convert fromusing our "Viewers" Group at Org level to this OTB Site level group. We just backed out of doing this, pending more understanding.
At this point, from the info page of EVERY user, that usershows thatthey are part of the View and Print Only Group, even though only about 1/4 of users were added to it. You can edit any user and remove the View and Print Only Group. On refresh it comes back. We tried every cache deletion, recompute, etc. It's very sticky. If you go to the info page of the View and Print Only Group and list the users, it correctly only displays the users that we added there.
We cannot figure out how to get all the users to not list that they are part of this group on their info pages.
Wondering if anyone has seen this and figure it out.
Tech support case C11856126 is pending. Seems like a major bug to us.
In Reply to Mike Lockwood:
Mike,
I am pretty sure this is a special group that is specifically intended for the not commonly advertised “View Print Only” licenses of Windchill, these are the cheaper licenses that are available if you beg your sales guy. As I understand things being in the group comes with limitations in the User Interface with an imposed profile and embedded access control.
Sounds like this is somehow impacting your entire organisation though, do you have a group at the org for all users? Has this somehow been added to the special View Print, or has your entire Org been put in there?
Lewis
Mike,
Where you able to get this to work?
Nope - never went back to try to use this OTB group.
On our test server I added one user to the group but it doesn't show up in that tab under Usage and License Reporting for some reason. I don't know why it's not showing that user.
I am using this group on Windchill 10.2 M030 and it's working fine. At the moment I have one test user and one Active Directory group added to it.
The Active Directory group contains both user and other groups and goes several levels deep. All of these users are being correctly resolved by the Usage and License Reporting tool.
This report only gets recalculated every so often (once per day???), so you won't see changes immediately.
There were a couple of times where I removed someone from a group and the change didn't show up immediately. Typically a "Recompute group" command, or (worse case) a server restart takes care of the issue.
Thank you for the info. I just tried the recompute but it didn't update it. Not a big deal. I might have to try and restart WC.
