Hello PTC Community ,
I`m working with the WT-Parts-Structure in Windchill. In our system the CAD-Documents are allready existing. I`m meanwhile able to create WT-Parts through "auto associate".
When I open the WT-Part-Structure through the function "show/hide" -> "CAD-Documents" all Referencedocuments appear e.g. the .prt-drawing and the .asm-drawing.
If I have for example a standard part and I create the associated WT-Part the Part-Structure also shows all the Assembly-Drawings where the standard part is used.
But I only want to see the .prt and the .drw-model of the standard part.
Are there any settings or filter options that I can use? Or is there already a mistake in creating the WT-Parts?
Thanking you in anticipation
This might be the preference which controls but not sure. The "Calculated Links" likely is the key thing to prevent.
"Disallow Product Structure Links by Document Types"
Where can I find the function "Disallow Product Structure Links by Document Types"? Can I find it in "My settings" -> "settings"?
Yes, a preference. Under Operation, Auto Associate. May be able to change from My Settings to test.
Ok, then I have to contact our system administration to change the settings.
Thank you very much.
