Version: Windchill 12.0
Use Case: Hello, when i am trying to publish an assembly drawing it is showingthe error is because it is timing out after 900 secs
Description:
when i am trying to publish an assembly drawing it is showingthe error is because it is timing out after 900 secs.
when i open the drawing in creo it regenerates it self everytime which is time consuming. could you please help how to get it published ?
sandy
There's a separate server involved for this.
https://www.ptc.com/en/support/wnc-publishing-troubleshooter?source=search
https://community.ptc.com/t5/Windchill-Customization/set-up-publishing-with-Solidworks/m-p/881355
First troubleshooting step: is the WVS publishing server down at the moment?
If the assembly takes more than 900 seconds to open and regenerate, you may want to ask your admins to increase the timeout value.
Hello @Sandy7,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N
Community Moderation Team.
You need to make 2 changes.
The first is to increase the timeouts in the recipe file.
The second is to set the publishing times in Windchill with xconfmanager in wvs.properties.
publish.cadtimeout.assembly=7200
publish.cadtimeout.component=600
publish.cadtimeout.drawing=1200
Adjust these times so your largest assemblies and drawings publish.
