Jun 15, 2023 2:05 PM UTC
set up publishing with Solidworks
Team
How do you set up publishing with Solidworks? We have it set up for CREO, but not for Solidworks.
thanks -- Rick
Jun 15, 2023 9:08 PM UTC
Please refer https://www.ptc.com/en/support/article/CS43894
Thanks!!
Jun 15, 2023 3:49 PM UTC
You would need a CAD worker running Solidworks. Setup would be similar to a Creo CAD worker, but you are installing Solidworks instead of Creo Parametric.
You would install Solidworks, Creo View Adapters, WGM.
Setup the worker agent configuration for the worker
rleir17-PeridotAuthor
Jun 15, 2023 7:16 PM UTC
Jun 15, 2023, 3:03:04 PM:Authoring Application: SolidWorks
Jun 15, 2023, 3:03:04 PM:Transferring Files to: /opt/ptc/Windchill_12/Windchill/tmp/pubtemp/publish10699999999999922461.tmp
Jun 15, 2023, 3:03:10 PM:Number of Files Transferred: 6
Jun 15, 2023, 3:03:10 PM:SolidWorks SldAsm Conversion
Jun 15, 2023, 3:03:11 PM:Error, did not find available worker of type SOLIDWORKS
Jun 15, 2023, 3:03:11 PM:SldAsm Processing Returned: $ERROR$ Error, did not find available worker of type SOLIDWORKS
Jun 15, 2023, 3:03:11 PM:CadAgent Returned: $ERROR$ Error, did not find available worker of type SOLIDWORKS
Solidworks, WGM and Creo View are already installed. WGM and CreoView are currently working fine with CREO but not with Solidworks.  The WGM Installation and Configuration manual is supposed to be on PTC's site, but it's not jumping out at me. Now it is:
https://support.ptc.com/help/creo/view/r9.0/en/index.html#page/creo_view/install_config_guide/ins_Overview.html#
Jun 15, 2023 9:03 PM UTC
Thanks!!
