Webject - 1st attempt
jlittle
8-Gravel
My first attempt at creating a webject in Windchill. I have a general understanding, but things just aren't coming together. I have the following jsp file located under an infoengine\jsp sub-directory. When I execute the JSP, I don't get any error messages, but I don't get any results either. What am I missing???
<%@page language="java"%>
<%@page import="wt.util.*"%>
<%@page import="wt.util.*, java.io.*"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
WTProperties wtprops = WTProperties.getLocalProperties();
String wtInstance = wtprops.getProperty("wt.federation.ie.VMName");
<process name="Generate" report&quot;=">
<description>Generates a report from the report template".</description>
<ie:webject name="Query-Objects" type="OBJ">
<ie:param name="INSTANCE" data="com.corning.na.kpwcdev.Windchill"/">
<ie:param name="TYPE" data="WCTYPE|wt.part.WTPart"/">
<ie:param name="ATTRIBUTE" data="name"/">
<ie:param name="WHERE" data="state.state='RELEASED"/">
<ie:param name="GROUP_OUT" data="PARTS"/">
</ie:webject>
<ie:webject name="Return-Groups" type="GRP">
<ie:param name="GROUP_IN" data="PARTS"/">
</ie:webject>
</process>
Any help is greatly appreciated.
James Little
CAD Admin
Corning Cable Systems
james.little@corning.com
ddemay
7-Bedrock
(To:jlittle)
While you can use Info*Engine tag library in any jsp, you have not defined
any way for the information to be displayed. Therefore, what you have so
far is more like a 'task' and should be placed in a directory under
$WT_HOME/tasks/some-directory/webject.xml and executed from the Info*Engine
replace the return-groups section with this and give it a shot.
<ie:webject name="Display-Table" type="DSP">
</ie:webject>
Glen Herman
Sr Application Developer
Engineering And Technology
Trane Residential Systems
6200 Troup Hwy
Tyler, Texas, 75701
Not confusing at all. Following your logic and going back over the
examples, I got the results for the example query I submitted below. I
now have another question. Trying to include a Document sub-type as
part of the WHERE statement, but can't get the syntax correct. The
class show up as:
WCTYPE|wt.doc.WTDocument|com.corning.Procedure
Any idea how I can filter for only a WTDocument that is classified as a
Procedure. Can this be part of the original query or should it be part
of the display webject? Also, would it make more sense to execute a
Search-Objects webject rather than a Query-Objects webject.
Thanks for the responses.
James Little
CAD Administrator
(817) 431-7678 - office
(817) 301-2274 - cell
Jeremiah 33:3 "Call to Me, and I will answer you, and show you great and
mighty things, which you do not know."
Change
to
<ie:param name="TYPE" data="WCTYPE|wt.doc.WTDocument|com.corning.Procedure"/">
then apply the where clause.
Search objects work very similar to Query Objects. One notable difference is Search Objects has Version arguments where Version="Latest" is useful.
Glen Herman
6200 Troup Hwy
Tyler, Texas, 75701
