We are happy to announce the new Windchill Customization board! Learn more.
Where I can download ProjectLink 11.2 zip ?
MattPat
I want to install ProjectLink to my Windchill 11.2. It requires ProjectLink 11.2 version but on PTC Software Download it's only Release 11.1. PTC Solution Installer doesn't let install with 11.1. Where I can find zip to download?
9 REPLIES 9
I cannot, there is only 11.1. It can be some troubles with access/license?
Are you on active maintenance?
Marco
I can see only this:
My question was certainly not a random one.
Version 11.2 was released this year in June.
If you don't see it, it means you're not in active maintenance or at least that's how it turns out at PTC.
Marco
BenLoosli
(To:MattPat)
Your list does not shoe Creo 6.0 either.
As Marco asked, "Are you on ACTIVE maintenance?"
Look in your license file to see if you have a subscription expired or only have Creo5/Windchill 11.1 licenses.
MattPat
(To:BenLoosli)
But Creo 6.0 is available in Creo Parametric context
TomU
(To:MattPat)
If you do have active maintenance, open a tech support case and ask why you can't get to the downloads.  I've had multiple instances over the past year where the newest download wasn't available for some reason and someone at PTC had to manually fix something in their release system before I was allowed access.
MattPat
(To:TomU)
Yes I am on active maintenance. I opened case 2 days ago and they working on it. Thank you 🙂
