We are aware of an issue causing intermittent login problems for some users following a recent update. Learn More
QML file does a "Where Used" report with just the latest version of both the searched for and returned objects. Uses EPM Documents, not WTParts.
-marc
CAD / PLM Systems Manager
TriMark Corporation
Marc, These are great and very helpful! Have you done any Query Reports with Family Tables? I'm working on the seven scenaries listed below. I have a line of site for 1,3,4,5 and 6. Item 2 is the one that I know will require some complicatd logic!
I haven't done any reports on family tables yet. We do use quite a few of them around here. So at some point, I am sure I will be asked to do one. Have you looked at the Resource for Reporting document that Marco Tosin created? There is a lot of good information there.
Yes...I've looked through the resource many times! There is only one report ever created for family tables...but it is missing almost every attribute that I need for the list above.
Still looking for the QML code for this column in the tables. Tech support hasn't been able to answer it yet and I've asked a couple experts without luck. I'm starting to hate Windchill UI more and more each day...I bet Teamcenter data model is much easier. They probably have it set up to where a user can drag and drop the column into the query report builder...
Bill,
I think you can select "Verified" from EPMDoc table.
What you'll see is Yes or No
If it was only that easy! The Verified is used in another query report I created to find all the assemblies in our database that will need to be repaired to build WTPart Product Structure. Reference case CS145803 which is where the picture below came from. You can associate WTParts against those assemblies in your picture, but try to build...you will see what I mean! You can also see Verification = no on items where family table status = 0 (which are not family tables)
Hi Marc,
I know I'm responding to a 10 year old comment so don't you if you are still active here. I was trying to do a similar task with query builder but want to return the top level assembly number rather than the next level up which I think this report returns.
Would you know what modifications I would need to make to pull that off?
Anthony
Still here.
Navigating up and down assembly structures isn't possible with Query Builder. At least I have never run into a solution, so being able to find the Top Level won't be possible.
- marc
