Why sometimes wtpart getting checked into windchill personal cabinet at site level, need help with reason and how can it be avoided.
This is expected :
This is expected :
All Workspace content is technically in the personal cabinet, any new object creations that only exist in the workspace are not checked out, but are not really checked in either, their location shows at the site. Typically this content is only visible to the user and Administrators, if these objects are showing up unwanted on a report, you can add criteria based on location to filter them out.
Hi @SA_12455883
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
