Hi Mike,
I was able to successfully run install_ccsdsu.xml on one of our file servers moving it from 10.1 F000 to 10.1 M010. I didn't get any of the errors you described, but the first time I did get:
“Unable to find the Naming Service directory entry”
The resolution was to keep WindchillDS running during the install. In the past when we've patched the file servers, we always turn of ALL Windchill services. I guess thepatching procedure is different from updating a M code.
Good luck finding a resolution to your issues.
