I also saw this post yesterday, but I did not solve the problem by using this method
Windchill version is 11.1M020-CPS08
2024-05-10 10:26:04,500 ERROR [ajp-nio-127.0.0.1-8010-exec-8] com.ptc.jca.error wcadmin - ---------- JCA Exception ----------
javax.servlet.jsp.JspException: java.lang.NoSuchMethodError: com.ptc.jca.json.table.TableConfigHolder.toJSONString()Ljava/lang/String;
at org.apache.jsp.tag.web.mvc.table_tag.doTag(table_tag.java:187)
at org.apache.jsp.WEB_002dINF.jsp.components.table_jsp._jspx_meth_mvc_005ftable_005f0(table_jsp.java:273)
at org.apache.jsp.WEB_002dINF.jsp.components.table_jsp._jspService(table_jsp.java:189)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:476)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:386)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:330)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at com.ptc.core.ui.validation.URLValidationFilter.doFilter(URLValidationFilter.java:85)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:728)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:470)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:395)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:316)
at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:170)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:314)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1325)
at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1069)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1008)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:925)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:974)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:877)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:648)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:851)
at com.lcs.wc.util.timeout.TimeoutFilter.doWithWtContextBeanHandler(TimeoutFilter.java:245)
at com.lcs.wc.util.timeout.TimeoutFilter.doFilter(TimeoutFilter.java:81)
at wt.licenseusage.licensing.LicenseFilter.doFilter(LicenseFilter.java:47)
at wt.httpgw.filter.WTContextBeanFilter.doWithWtContextBeanHandler(WTContextBeanFilter.java:104)
at wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:58)
at wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:301)
at wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:335)
at wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1660)
at wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:56)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:493)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:137)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.ajp.AjpProcessor.service(AjpProcessor.java:476)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:808)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1508)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.NoSuchMethodError: com.ptc.jca.json.table.TableConfigHolder.toJSONString()Ljava/lang/String;
at com.ptc.core.components.rendering.table.DefaultTableRenderer.drawTable(DefaultTableRenderer.java:944)
at com.ptc.core.components.rendering.table.DefaultTableRenderer.drawLegacyTable(DefaultTableRenderer.java:460)
at com.ptc.core.components.rendering.table.DefaultTableRenderer.draw(DefaultTableRenderer.java:388)
at com.ptc.core.components.tags.components.AbstractRenderTableTag.drawNmModel(AbstractRenderTableTag.java:36)
at com.ptc.core.components.tags.components.RenderModelTag.render(RenderModelTag.java:313)
at com.ptc.jsca.RenderJSTableTag.render(RenderJSTableTag.java:63)
at com.ptc.core.components.tags.components.RenderModelTag.doTag(RenderModelTag.java:204)
at org.apache.jsp.tag.web.mvc.table_tag._jspx_meth_comp_005frenderTable_005f0(table_tag.java:206)
at org.apache.jsp.tag.web.mvc.table_tag.doTag(table_tag.java:169)
Hi @HL_10070408
And what changes have you done in your system ?
The error is not usually thrown without reason.
It seams that you have problem with com.ptc.jca.json.table.TableConfigHolder.toJSONString() method.
This method does not exist or there is some null value...
PeetrH
Hello @HL_10070408,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
This problem may be caused by my lack of documents. I plan to go through my previous process again
