Windchill 10.x indexing jumbling text bug - SPR#2133672
vmcdaniel
We noticed this in April 2012 (C10793504) on our Windchill 10.0 M030 system when PDF files were getting returned in search results that should not be, and the correct ones would not show up.
It turns out that the software PTC is using, Tika to index the PDF files, jumbles the words all up; example below.
I expect others have similar, but un-diagnosed issues. I am disappointed that I still have no patch, or SPR resolution on a valuable significant piece of core Windchill functionality that got broken when we upgraded from 9.1.
My goal with this email is to shed light on this in the community, so more attention is put to resolving this issue. If you have seen this please speak up. If you have any workaround I would also be very interested.
-Vaughn
-----EAXMPLE-------
The parts DAET FO PURCHASE _________ lists include a number of columns of information: SERIAL UNMEBR ______ SALES REPRESAETNTIVE # ___ ___ - REF – column refers to the reference EDAELR NAME _________ number on the parts illustration. OPERAITOSN GUIED UNMEBR ____ - PART NO. – column lists the part number for the part. PUSILBEHD ________________________________ - RP V.ON – reference number - QTY –column lists the quantity of the part used in that area of the machine. - SEDCR NOITPI –column is a brief The model and serial number of your machine is on description of the part.-----------------------
0 REPLIES 0
