After upgrading to Windchill 12 Audit Log Purge Management page stopped showing purge results. Does this mean that this page really stopped working in showing purge job results after Windchill 11.2?
Right, it works prior to 11.2, and only shows results from runs prior to 11.2. Seems like someone should have removed it.
This is what I see. It shows a list of the purged objects. What is missing?
Is that from 'Purge Management' or 'Audit Log Purge Management'?
I"m on 12.1.2.0 and I'm not seeing anything useful on the 'Audit Log Purge Management' screen...
my bad, Purge Management, Doh!
Hi Tom, And I suppose you are running audit log purges on regular basis?
No, not on a regular basis, but I have definitely run some in the past. They show up on the 'Audit Log Purge Scheduler' page:
Found it: CS341757
But it's still there under Auditing Administration section. But it's not working I guess.
