Hi everybody !
I am very new to this forum & very beginner to windchill 10.1.
Is this possible to add constraint to an attribute through program.
(ex. SingleValuedConstraint, LegalValueList)
Using this code has one demerit
The OOTB processor can’t persist the value so you have to write a custom processor also.
For WC 9.1:
In my experience, manipulating the AttributeContainer of the IBAHolder and the related View objects is overly complex. That statement's probably debatable, but directly manipulating the Persistable constraints seems much easier.
Here's an example of creating a DiscreteSet constraint:
Object values[] = new Object[]{"Blue","Red","Green"};
DiscreteSet ds = new DiscreteSet(values);
WTTypeDefinition td = ....
AttributeDefinition ad = ....;
TypeSingleAttrConstraint constraint = new TypeSingleAttrConstraint();
constraint.setTypeDefinition(td);
constraint.setAttributeDefinition(AttributeDefinitionReference.newAttributeDefinitionReference((AbstractAttributeDefinition)ad));
constraint.setBindingRuleClassName(SingleAttributeConstraintBindingRule.class.getName());
constraint.setEnforcementRuleClassName(DiscreteSetConstraint.class.getName());
constraint.setEnforcementRuleData(ds);
constraint = save/insert(constraint);
You may want to clear/reset any applicable cache afterwards.
Thanks Matthew.
I am in 10.1 and what I want to do is suppose there is one soft attribute of Document named "New". Now I need a dropdown box in the UI with some value like the attached picture and again that attribute will be a multi valued attribute.
So, how to do that?
I want to give the value programmatically cause those values will come from a txt file.
Any suggestion please
Use Lov type attribute and give values seperated by "|".
but that will be from UI ,my value is coming from a text file so I have to give value programmatically
Have you considered using a DataUtility to read your text file and populate the drop-down when the UI is rendered?
Yes I tried that I used the StringInputComponent to make a dropdown list but I have to again make it a MultiValuedAttribute there I am stuck ![]()
Does the stuff I gave you not work in 10?
We defined our own MultiSelectDisplayComponent and renderer. Then we used it in a Data Utility to display a multi-select list of values.
MultiSelectDisplayComponent.java:
import com.ptc.core.components.rendering.guicomponents.*;
import java.util.ArrayList;
public class MultiSelectDisplayComponent extends AttributeGuiComponent implements PrintableComponent
private static final long serialVersionUID = 1L;
String attributeName;
int numberOfDisplayLines = 0;
ArrayList<String> keyValues;
ArrayList<String> displayValues;
ArrayList<String> selectedValues;
public MultiSelectDisplayComponent( String attrName, ArrayList<String> keys, ArrayList<String> displayV, ArrayList<String> selectedV, int numLines)
attributeName = attrName;
keyValues = keys;
numberOfDisplayLines = numLines;
selectedValues = selectedV;
displayValues = displayV;
setRenderer(new MultiSelectDisplayComponentRenderer());
public String getPrintableValue()
return "";
MultiSelectDisplayComponentRenderer.java:
import com.ptc.core.components.rendering.*;
import java.io.PrintWriter;
import java.util.Vector;
import wt.util.WTContext;
import java.lang.reflect.Method;
import wt.util.WTStringUtilities;
import wt.fc.EnumeratedType;
public class MultiSelectDisplayComponentRenderer extends AbstractRenderer
public MultiSelectDisplayComponentRenderer()
protected void renderObject(Object obj, PrintWriter pw, RenderingContext rc)
throws RenderingException
renderObject((MultiSelectDisplayComponent)obj, pw, rc);
protected void renderObject(MultiSelectDisplayComponent comp, PrintWriter pw, RenderingContext rc)
write(pw, buildMultiSelectComponent(comp));
protected String buildMultiSelectComponent(MultiSelectDisplayComponent dispComp)
//System.out.println("+++ In MultiSelectDisplayComponentRenderer.buildMultiSelectComponent()");
String htmlString;
Vector<String> theList = new Vector<String>();
String s1 = null;
int numLines = dispComp.numberOfDisplayLines;
if (numLines <= 1 ) numLines = 4;
if (dispComp.selectedValues != null) {
for (int j=0; j<dispComp.selectedValues.size(); j++){
theList.add(dispComp.selectedValues.get(j));
htmlString = "<select ";
htmlString = htmlString + "name= \"" + dispComp.attributeName + "\" id = \"" + dispComp.attributeName + "\"";
if (dispComp.isRequired()) {
htmlString = htmlString + " class = \"required \"";
htmlString = htmlString + " multiple size=" + numLines;
htmlString = htmlString + ">\n";
try {
for (int k=0;k< dispComp.keyValues.size(); k++) {
if ( dispComp.selectedValues == null ) {
String stringV = dispComp.keyValues.get(k);
String displayV = dispComp.displayValues.get(k);
htmlString +=" <OPTION VALUE=\"" + stringV + "\">" + displayV + "\n";
} else {
boolean selected;
if ( dispComp.selectedValues != null) {
selected = dispComp.selectedValues.contains(stringV);
} else {
selected = false;
if (selected) {
htmlString +=" <OPTION VALUE=\"" + stringV + "\" selected>" + displayV + "\n";
} else {
} catch ( Exception ex ) {
ex.printStackTrace();
htmlString += "</select>";
//System.out.println("+++ Leaving MultiSelectDisplayComponentRenderer.buildMultiSelectComponent()");
return htmlString;
protected boolean isValidForObject(Object obj)
return obj instanceof MultiSelectDisplayComponent;
Usage in Data Utility.getDataValue method:
MultiSelectDisplayComponent multiSelectComp = new MultiSelectDisplayComponent(compId, keyValues, displayValues, selectedValues, listSize);
multiSelectComp.setRequired(isRequired);
return multiSelectComp;
Theresa I implement your solution It working fine as a multiselect
thanks for that ..
But what I want is a littile different .
I need the functionality of MultiValued attribute like that plus or minus button
Thanks everyone for your answers finally I got the answer after backtracking the OOTB functionality.
I ve the same problem to resolve. Could you explain to me how you succeed to get a multi valuated component with suggested list? backtracking OOTB functionality? Tank's a lot. I am on the PDMLink 10.4.
Hi Kaushik,
Thanks for sharing the code. Please share the processor src too. this will help a lot.
Thanks in Advance.
I assume that the IBA’s internal name is VendorName and it’s only in a specific subtype of WTDocument whose
internal name is com.ptc.Agenda.
For Create Mode :-
package ext.customization.processor;
import java.util.Arrays;
import java.util.Enumeration;
import java.util.HashSet;
import java.util.Iterator;
import java.util.List;
import javax.servlet.http.HttpServletRequest;
import wt.doc.WTDocument;
import wt.fc.ObjectReference;
import wt.fc.Persistable;
import wt.fc.PersistenceHelper;
import wt.folder.Folder;
import wt.util.WTException;
import com.ptc.core.components.beans.ObjectBean;
import com.ptc.core.components.forms.FormResult;
import com.ptc.core.lwc.server.LWCNormalizedObject;
import com.ptc.core.meta.common.TypeIdentifierHelper;
import com.ptc.core.meta.common.UpdateOperationIdentifier;
import com.ptc.netmarkets.util.beans.NmCommandBean;
import com.ptc.windchill.enterprise.doc.forms.CreateDocFormProcessor;
import com.ptc.windchill.wp.delivery.DeliveryRecord;
public class CustomDocProcessor extends CreateDocFormProcessor
@SuppressWarnings({ "rawtypes", "unchecked" })
@Override
public FormResult postProcess(NmCommandBean paramNmCommandBean,
List<ObjectBean> paramList) throws WTException
/* Taking the object of WTDocument which is created form the CreateDocFromProcessor*/
WTDocument localWTDocument = null;
for (Iterator localIterator = paramList.iterator(); localIterator.hasNext(); )
localWTDocument = (WTDocument)(((ObjectBean)localIterator.next()).getObject());
try{ /* Checking whether the WTDocument is of desired subtype */
if(( TypeIdentifierHelper.getType(localWTDocument).toString().equals("WCTYPE|wt.doc.WTDocument|
com.ptc.Agenda ")))//internal name of your subtype
HttpServletRequest req = paramNmCommandBean.getRequest();
Enumeration em = req.getParameterNames();
String temp = null;
while(em.hasMoreElements())
String name="VendorName";//internal name of your iba
String old = "old";
temp = em.nextElement().toString();
if(temp.contains(name) && !temp.endsWith(old))
break;
//Giving value to the soft attribute
LWCNormalizedObject obj = new LWCNormalizedObject(localWTDocument,null,null,new
UpdateOperationIdentifier());
//removing duplicate value
obj.load("VendorName");
obj.set("VendorName",(String[])new HashSet( Arrays.asList( req.getParameterValues(temp) )
).toArray( new String[]{} ));
/*persisting the value of IBA after removing duplicate value*/
obj.apply();
PersistenceHelper.manager.modify(localWTDocument);
catch(WTException e)
e.printStackTrace();
// TODO Auto-generated method stub
return super.postProcess(paramNmCommandBean, paramList);
For Edit
import java.util.*;
import com.ptc.core.components.forms.EditWorkableFormProcessor;
public class CustomEditDocProcessor extends EditWorkableFormProcessor
@SuppressWarnings("rawtypes")
@Override
/* Taking the object of WTDocument which is created form the EditWorkableFormProcessor*/
try
if( (
TypeIdentifierHelper.getType(localWTDocument).toString().equals("WCTYPE|wt.doc.WTDocument|com.ITCINFOTECH.VendorPart")))
String temp = null;
String old = "old";
break;
@SuppressWarnings({ "unchecked" })
String[] s = (String[])new HashSet( Arrays.asList( req.getParameterValues(temp) ) ).toArray( new
String[]{} );
List<String> list = new ArrayList<String>();
for(String str : s)
if(str != null && str.length() > 0)
list.add(str);
s = list.toArray(new String[list.size()]);
/* After removing any blank string from String array */
obj.set("VendorName",s);
obj.apply();
Thanks And Regards,
Kaushik
Hi Kaushik,
Is there a way to fetch all the attributes for a given subtype?
Is there a way to pull the metadata of the fetched attribute?
For example, i have a subtype of "CustomerExperience" object and many attributes configured on this subtype.
I am trying to fetch all the MBA(Model Based Attributes) and IBA(Instances Based Attributes), and after that fetch all the constraints,default values, datatype etc.. i.e metadata of the attribute
RK
Hi RK,
To fetch all the IBA's of a given softtype use below method.
public static ArrayList<String> getIBAInformationForSoftType(
String internalName) {
ArrayList<String> logicalNames = new ArrayList<String>();
LogicalIdentifierFactory factory = new LogicalIdentifierFactory();
TypeIdentifier ti = factory.newWCTypeIdentifier(internalName);
GetSoftSchemaAttributesCommand command = new GetSoftSchemaAttributesCommand();
command.setType_id(ti);
try {
command = (GetSoftSchemaAttributesCommand) command.execute();
AttributeTypeIdentifierSet atis = command.getAttributes();
Iterator iter = atis.iterator();
while (iter.hasNext()) {
AttributeTypeIdentifier ati = (AttributeTypeIdentifier) iter
.next();
if (!ati.getAttributeName().equals("view")) {
try {
String name = ati.toLogicalForm();
logicalNames.add(name);
System.out.println("Logical identifier of the IBA :- " + name);
} catch (Exception e) {
} catch (CommandException e) {
return logicalNames;
Kaushik
Hi Kaushik,
Happy new year. Thanks you so much for repying.
I tried the snippet however it fetches only the IBAs. I am trying to fetch both IBAs and MBAs, i.e. all attributes(instance based and model based). Any furthur updates on all attributes is really helpful.
RK
Hello Ramakrishna,
Happy new year to you to.
For MBA try below snippet.
public static ArrayList<String> getIBAInformationForHardType(String className) {
ArrayList<String> attributes = new ArrayList<String>();
TypeIdentifier ti = factory.newWCTypeIdentifier(className);
GetHardSchemaAttributesCommand command = new GetHardSchemaAttributesCommand();
try {
command = (GetHardSchemaAttributesCommand) command.execute();
while(iter.hasNext()){
AttributeTypeIdentifier ati = (AttributeTypeIdentifier) iter.next();
if(!ati.getAttributeName().equals("view")){
String name = ati.getAttributeName();
System.out.println(name);
attributes.add(name);
return attributes;
getIBAInformationForHardType("wt.doc.WTDocument")
Thanks and Regards,
Kaushik
I also need to add plus minus sign to multiValuedAttribute, Please provide the code of how you have done.
Hi, in 10.2 you have this OOTB, called "External Enumerated Value List". There you can pull the values from a text file or even from a DB like ERP.
Hi Kaushik,
I have one doubt. I have one custom column. I want to publish the value of distribution target there. How can I get the value of Distribution target name or number in that column?
I mean, how can I fetch the data of Distribution target IBA there?
Sakil
