Windchill advanced search with csv-file?
GS_4867400
7-Bedrock
Version: Windchill 11.1
Use Case: Search CAD-Documents in Windchill with a csv.-file.
Description:
Hi All,
I have a request to export a larger amount of CAD data from Windchill. So that I don't have to export them manually one by one, I wanted to do this via the advanced search and load them all into a workspace at the same time.
Is there a way to start an advanced search in Windchill using a csv file?
HelesicPetr
(To:GS_4867400)
Hi @GS_4867400
Generally the answer is no.
The advanced search input is always in the UI not from a file.
Also you can use separator in the number as a semicolon ";" and search more objects by number at one search.
PetrH
5 REPLIES 5
HelesicPetr
(To:GS_4867400)
Hi @GS_4867400
PetrH
My solution is now, to export the csv. to a notepad++ File and put all numbers in a row. From there i export the the numbers with semicolon ";" to the Windchill-Search.
HelesicPetr
(To:GS_4867400)
That's it what I mentioned..
It is all what you can do and I think there is also some string limit for the search key.
PetrH
Better way is to use Excel to concat number with a semicolon and the row above. Fill down it will keep adding each number to the increasing string. If it gets too long like @HelesicPetr mentioned, just take a grouping just under limit and restart the formula from that point down.
HelesicPetr
(To:avillanueva)
Yes @avillanueva
And also It depends on a user skill to work with the Excel 😄
PetrH
