Worker Agent does not start
SOLVED
Re: Worker Agent does not start
For those with a similar problem in the future.. Solution was:
Enter in command prompt "hostname", and make sure the server in D:\ptc\creo_view_adapters\sw_setup\adapter.pvi and the worker administration configuration host have the same value as the one returned by the command prompt.
This value is not necessarily the Windchill URL (part in bold) XYZ.com\Windchill\app... It was the computer name...
Good luck,
Ammar
hello
            I am trying the same but my agent.ini file is still empty after configuring the worker agent.
Is agent.ini generates scripts inside it automatically when we configure worker agent OR we have to manually set the script in agent.ini file
let my host name is: test.com
so what will be exact values in wvs properties
i am getting the following values (worker.exe.whitelist.prefixes=C\:/ptc/creo_view_adapters/proe_setup)
and what about the second script , what is the exact script to execute  (worker.exe.whitelist.prefixes.<worker_host>)
please any one tell me the exact script to run with my host name
thanks in advance
Nimish
