The structure tab has a left and right window.
You should be able to resize the tables on the right side though. I just tested on an 11.0 M020 CPS 19 system and was able to resize the table in the right hand side for Supersedes tab.
Thanks for the reply. That's interesting how you can do it but I can't. I tried it in Edge and Chrome and both have same error. I guess it's something local to my computer.
Thanks again.
I was using Firefox as my browser, but just tried in Chrome and Edge and was able to resize in all three browsers.
I'm using Windchill 11.1 M020-CPS14 Edge. I can resize the Supersedes table, but not any of the tables in the Documents tab. Interesting behavior indeed.
You are correct. While I could resize Supersedes table, I also was not able to resize the tables in documents tab. That is unexpected but appears to be consistent across browsers.
Hello kmccormack-2,
I'm Charles from PTC Tech support in Europe: I also observe some tables (e.g. Supersedes) can be resized, whereas some others cannot.
Will you need further information on this topic?
KR,
Charles.
thanks Charles. Yes, that is the issue. I'm looking for solution and information to have all the tables resizable, not just some of them. thanks, kenny
May I suggest you open a new case from the Tech Support page, and please select 'customization' as type of question.
KR,
Charles.
ok thanks. will do.
Hello kmccormack-2,
Will you need further information?
KR,
Charles.
no further info. thanks
no
