hi, there
I often encountered a ghost file issue (see Figure1) when I was checking in the files which had been done.
1. Actually, when i checked out the assembly drawing into the workspace, there was no one ghost file in workspace.
2. After i did some changes about the assembly drawing and saved it, then the ghost shown up.
3. when i succeeded in checking in them, the ghost file disappeared and had not been checked in.
when i make any changes in the drawing next time, they will show up again.
Is there anyone who can give me a clue?
thanks
hi,you guys,
thank you so much.
I make it, here are the steps.
I`m sure that were caused by some improper references.
We have to pay more much attention on these:
circular references
unused substitute object dependencies
interchange dependencies
