Community login and other support tools will be unavailable Saturday May 3rd 9:00 am to 3:00 pm (EST) due to planned maintenance. Learn More
ms sequel server on Linux
rleir
Team
The req'ts for DB for WC (12.0.2.11) are:
  • MS SQL Server Enterprise & Standard 2016+
  • MS SQL Server Enterprise & Standard 2017+
  • MS SQL Server Enterprise & Standard 2019
  • Oracle 18c Enterprise & Standard 18.3.0.0.0+
  • Oracle 19c Enterprise & Standard 19.0.0.0.0+
Does this assume that MS SQL is running on Windows? Who has experience running MS SQL on Linux? Redhat says it is a good choice:
https://www.redhat.com/en/explore/microsoft-sql-server-on-rhel
https://www.redhat.com/en/technologies/linux-platforms/enterprise-linux/sql-server
MS says some features are not supported:
https://learn.microsoft.com/en-us/sql/linux/sql-server-linux-editions-and-components-2022?view=sql-server-ver16#unsupported-features-and-services
I prefer Linux and would like to know your experiences
cheers -- Rick
7 REPLIES 7
VladimirN
(To:rleir)
For Linux you can also consider as an option - PostgreSQL.
rleir
(To:VladimirN)
For ThingWORx, yes. But for Windchill? Are you sure? ( I hope you are right).  Are the published req'ts incorrect?
VladimirN
(To:rleir)
rleir
(To:VladimirN)
Let's not talk about Postgres here.
The question is about WC 12.0.2.11 running with MS SQL: who has experience running the MS SQL DB on Linux?
thanks -- Rick
HelesicPetr
(To:rleir)
Hi @rleir
I am sure that 2017 is supported.
The best thing is to try installing the MSSQL on the linux.
It is possible.
https://learn.microsoft.com/en-us/sql/linux/sql-server-linux-setup?view=sql-server-ver16
Some features are not supported but are not supported  features really so needed for Windchill? I don't think so .
so go for it.
PetrH
rleir
(To:HelesicPetr)
the PTC guide to configuring MSSQQL (link below) says you should use the Windows collation (otherwise known as a character set) Latin1_General_100_CS_AS_SC.
But we have Windchill on RedHat, and MSSql on RedHat ... why would we want to use a Windows collation?
This Latin1_General_100_CS_AS_SC represents a base collation of
   Latin1_General_100
with some modifiers:
  •  Case-sensitive,
  • Accent-sensitive and
  • Supplementary characters
Just maybe this results in a Linux-friendly collation?
https://support.ptc.com/help/windchill/r12.1.2.0/en/index.html#page/Windchill_Help_Center/WCInstallConfigGuide/WCInstall_SQLBeforeBegin.html#
HelesicPetr
(To:rleir)
Hi @rleir
a general answer is because Microsoft 😄
I set the collection manually in the past if the collection was not in the list that PTC guide mention to use with MSSQL.
Latin1_General_100 with correct set CS AS SC is ok to use in my opinion.
PetrH
