I'm new with Windchil, and I hope this is the correct forum. I have inherited a situation as follows...
We havepart A.prt with drawing A.drw all fine and dandy in Winchill 9.1. Then "someone" created a new version of A.prt, called B.prt WITHOUT carrying the drawing along. So I am wondering if there is a simple way to RELINK the A.drw to the B.prt within the context of Windchill.
I think one option would be to export A.prt, A.drw and B.prt. Then do the typical Pro/E relink; open B.prt, rename it in session to A.prt, open A.drw then rename both to B.prt/drw and save. Then I should be able to import B.prt and B.drw back into Windchill.
thanks in advance...
(and apologies if this isn't the correct foum... what would be the correct one?)
