windchill
  • February 2, 2026
  • 367 views
Version: Windchill Below 11.0
Use Case: start of Windchill User Interface
Description:
I have a small issue with starting Windchill, I tried to find the solution alone today but I can’t, I have the following error message:2026-02-02 15:57:36,162 ERROR [wt.intersvrcom.SiteMonitor.timer] wt.intersvrcom.SiteMonitor - Names=[master], URL=http://tls-vsrvdcns19.marc.fr.ssg:81/Windchill/servlet/WindchillGW, Status=SITE NOT RESPONDING, ResponseSeconds=1.003, TimeOfPing=2026-02-02 15:57:33.149 +0100
Hi @AL_10371359,
Is your Method Server instance Started?
If so, could you please share the Method Server logs?
If it is not Started, could you instead provide the Server Manager logs?
Yes the method server is launched,
See Methode Server.log
Thanks for your help
Best Regards,
Albert
Sorry, my bad.
The Powershell command is 'tnc' (test network connection), not 'tns'.
The Windchill shell commands are 'xconfmanager -d', not 'windchill -d'.
I just updated the commands in my previous response.
But I believe your smoking gun is the Apache server name.  It hasn't been rehosted.  Apache thinks it is 'paloma.marium.int' and Windchill thinks it is 'tls-vsrvdcns19.marc.fr.ssg'.
Rehost Apache.
pushd %WT_HOME%\..\HTTPServer
ant -f config.xml reconfigure -DServerName=tls-vsrvdcns19.marc.fr.ssg
Validate the configuration is 'OK'.
%wt_home%\..\HTTPServer\bin\httpd.exe -t
Restart Apache and try the URL again.
