wt.load.LoadFromFile
  • May 31, 2023
  • 2 replies
  • 3434 views
windchill shell:
windchill wt.load.LoadFromFile -d "D:\PTC\Windchill_12.0\Windchill\src\loadFiles/users.xml"--javaargs="-Dcom.ptc.net.auth.user="wcadmin" -Dcom.ptc.net.auth.password="wcadmin"" -CONT_PATH \"/wt.inf.container.OrgContainer=xxx\"
Error:
The operation:   "getPrincipal" failed.
Nested exception is: wt.util.WTRemoteException: Unable to invoke remote method
Nested exception is: wt.method.AuthenticationException
Resolution tried:
1. keytool -import -alias someAliasName -file C:\ptc\Windchill_12.0\HTTPServer\conf\server.crt -storetype jks -keystore c:\ptc\JDK11\lib\security\jssecacerts
2. ant -DHTTPS_ENABLED=true -f config.xml reconfigure
3. Restarted all Apache services
and tried to run the windchill wt.load.LoadFromFile"". still facing the same issue, any suggestions
Best answer by HelesicPetr
Hi @NSS
Is the certificate generated to specific server name with full domain? There are several troubles if the certificate is in chain.
Use any app to open the keyStore and check if the store really contains your certificate with correct windchill server name
PetrH
avillanueva
23-Emerald I
23-Emerald I
May 31, 2023
Is it your quotes around wcadmin? You also seem to have mixed slashes in your path for the load file.
HelesicPetr
Hi @NSS
I would check all cases described in the article https://www.ptc.com/en/support/article/cs82453
Check if the certificate is really the one that should be used and is really in the key store.
ps: why do you use javaargs instead of -u and -p arguments ?
I would like to see a methodserver log file because the error "getPrincipal failed" show me that the principal may not exist
PetrH
NSS14-AlexandriteAuthor
I have used  javaargs by referring this article https://www.ptc.com/en/support/article/CS63015
avillanueva
23-Emerald I
23-Emerald I
May 31, 2023
correct but you do not need quotes around username and password values.
 --javaargs="-Dcom.ptc.net.auth.user=<username> -Dcom.ptc.net.auth.password=<password>"
