wt.load.LoadFromFile
NSS
windchill shell:
windchill wt.load.LoadFromFile -d "D:\PTC\Windchill_12.0\Windchill\src\loadFiles/users.xml"--javaargs="-Dcom.ptc.net.auth.user="wcadmin" -Dcom.ptc.net.auth.password="wcadmin"" -CONT_PATH \"/wt.inf.container.OrgContainer=xxx\"
Error:
The operation:   "getPrincipal" failed.
Nested exception is: wt.util.WTRemoteException: Unable to invoke remote method
Nested exception is: wt.method.AuthenticationException
Resolution tried:
1. keytool -import -alias someAliasName -file C:\ptc\Windchill_12.0\HTTPServer\conf\server.crt -storetype jks -keystore c:\ptc\JDK11\lib\security\jssecacerts
2. ant -DHTTPS_ENABLED=true -f config.xml reconfigure
3. Restarted all Apache services
and tried to run the windchill wt.load.LoadFromFile"". still facing the same issue, any suggestions
HelesicPetr
(To:NSS)
Hi @NSS
Is the certificate generated to specific server name with full domain? There are several troubles if the certificate is in chain.
Use any app to open the keyStore and check if the store really contains your certificate with correct windchill server name
PetrH
10 REPLIES 10
avillanueva
23-Emerald I
(To:NSS)
Is it your quotes around wcadmin? You also seem to have mixed slashes in your path for the load file.
HelesicPetr
(To:NSS)
Hi @NSS
I would check all cases described in the article https://www.ptc.com/en/support/article/cs82453
Check if the certificate is really the one that should be used and is really in the key store.
ps: why do you use javaargs instead of -u and -p arguments ?
I would like to see a methodserver log file because the error "getPrincipal failed" show me that the principal may not exist
PetrH
NSS
(To:HelesicPetr)
I have used  javaargs by referring this article https://www.ptc.com/en/support/article/CS63015
avillanueva
23-Emerald I
(To:NSS)
correct but you do not need quotes around username and password values.
 --javaargs="-Dcom.ptc.net.auth.user=<username> -Dcom.ptc.net.auth.password=<password>"
NSS
(To:avillanueva)
I have tried both with and w/o quotes and also please ignore mixed slashes too as I mentioned earlier
it throws same error.
avillanueva
23-Emerald I
(To:NSS)
Let's take a step back. You can leave off that block and let system prompt you for login. Also, have you tried wt.auth.Authentication to verify that login is working?
NSS
(To:avillanueva)
wt.auth.Authentication failed.
DEBUG wt.httpgw.HTTPLogin - Failed to get input stream from connection
javax.net.ssl.SSLHandshakeException: No name matching xxx.com found.
Also, next step "wt.server.codebase" value is not getting updated in wt.properties.
HelesicPetr
(To:NSS)
Hi @NSS
This error tells you that the ssl certificate in the key store is wrong. So you need to import correct one.
PetrH
NSS
(To:HelesicPetr)
Hi PetrH,
ssl certificate created by me and followed the steps in the article for importing.
would you like to suggest any idea here on verify the same or any other possibilities.
HelesicPetr
(To:NSS)
Hi @NSS
PetrH
