wt.util.WTException: java.lang.NullPointerException on upload or checkin, anyone seen this, cannot find a way around this?
kjohns101
I have tried almost everything to check in or upload a large assy with this error--wt.util.WTException: java.lang.NullPointerException
TomU
(To:kjohns101)
It most likely has something to do with references. Try backing up to disk, removing from the workspace, and then reopening from disk. Also take a look at the reference viewer.
Tom U.
msteffke
(To:kjohns101)
Maybe a long shot but check w your admin, if they could look in the methodserver log files and perhaps there would be a little more detail of what object was causing this exception, or see what was processing right before the exceptions started.
