Feb 27, 2024 11:56 AM UTC
Custom Message Handler
Hi all. I'd like to set up a custom message handler on Thingworx 9.4.3 and I'd like to use telegram.
Wondering if anyone has done this before or can provide me with steps to achieving this.
NiKlausAnswer
Apr 11, 2024 6:28 AM UTC
Here is where I found the solution:
https://support.ptc.com/help/thingworx/platform/r9.5/en/#page/ThingWorx/Help/Composer/Things/ThingSubscriptions/ThingSubscriptions.htmlhttps://support.ptc.com/help/thingworx/platform/r9.5/en/#page/ThingWorx/Help/Composer/Things/ThingSubscriptions/ThingSubscriptions.html
var message = "New Event with type: " + eventName + ". " + ThingName + "'s " + propName + " changed from " + oldValue + " at " + oldValueTime + " to " + newValue + " at " + newValueTime + ".";
handlerIDs = NotificationDefinitions["Sample_RoA"].GetAvailableHandlers();
//handlerID = handlerIDs.rows[3].handlerID;
var handlerIDsList = handlerIDs.rows;
var telegramHandlerID = "";
for(var i = 0; i < handlerIDsList.length; i++) {
 // Check if contentName contains 'Telegram'
 if(handlerIDsList[i].contentName.indexOf("Telegram") !== -1) {
 telegramHandlerID = handlerIDsList[i].handlerID;
 break; // Exit the loop once the ID is found
//logger.warn("handlerID: " + telegramHandlerID);
//logger.info("handlerID: " + telegramHandlerID);
var UserRecipients = NotificationDefinitions["Sample_RoA"].GetUserRecipientsOfEvent({
 handler: telegramHandlerID /* STRING */,
 propertyName: propName /* STRING */,
 alertName: "" /* STRING */,
 entityType: "Thing" /* STRING */,
 entityName: ThingName /* STRING */,
 eventName: eventName /* STRING */
//logger.warn("Recipient List: " + UserRecipients.rows);
var UserRecipientsList = UserRecipients.rows;
for (var j = 0; j < UserRecipientsList.length; j++){
 var User = UserRecipientsList[j].name;
 let params = {
 headers: {
 token: token/*token from the configuration*/
 url: 'https://api.telegram.org/bot'+token+'/sendMessage',
 content: {
 chat_id: Users[User].TelegramID, //this is the telegram user ID= '-xxx’
 text: message
// logger.warn("message: " + message);
 let post = Resources["ContentLoaderFunctions"].PostJSON(params);
Rocko
Feb 27, 2024 12:51 PM UTC
Telegram has a REST Bot API https://core.telegram.org/bots/api#authorizing-your-bot
In ThingWorx you would use Resources["ContentLoaderFunctions"].PostJSON or one of its other services to send the data.
The tricky part is the authorization but this is usually done by creating an appKey in the target system (here telegram) and putting in into the message header.
For ease of development, you create and test the requests with Postman and then move them over to TWX once they're working.
Hi @NiKlaus
Look at the below article for your reference.
https://www.ptc.com/en/support/article/CS395620
NiKlaus12-AmethystAuthorAnswer
 let params = {
 headers: {
 content: {
 text: message
