Set gadget configuration parameter
I have a gadget that has a configuration parameter "dataset" identifying the thing it should display. I can add this gadget to the dashboard, but how can I set the configuration parameter (either UI or via script), so that the gadget is properly configured on startup?
For test purposes I can embed this gadget into a static mashup and bind the configuration parameter. This works fine, but for the dashboard this needs to be dynamic and set by the user.
EDIT: I was able to call DashboardFunctions.AddDashboardItem and set the parameters argument to my desired params. I do this in a scripted call. This works for me.
Thanks. Much appreciated!
