SSO Plug In
  • May 8, 2015
  • 1115 views
Hi All,
Has anyone had any experience with the SSO Plug-In in Thingworx?
If so, could you please tell me if it supports Jasig CAS out of the box?
    Hi James,
    Not sure if you had a chance to read up on the SSO support within Thingworx, but it is an extension that exposes hooks to a user so they can build an SSO Extension for their particular need.
    Also if you haven't seen it yet, the new 6.0 comes with a full Java Doc: http://support.ptc.com/cs/help/thingworx_hc/thingworx_6.0_hc/
