Nov 26, 2024 9:51 AM UTC
Thingworx 9.6.1 SSO issue
Hi, we use Thingworx 9.5.1 With SSO login and that works good , all parameters for reverse proxy we implemented like in the CS : CS327279 - "Incoming SAML message is invalid" "Endpoint with message binding <Binding> and URL <URL> wasn't found in local metadata" is logged in the SecurityLog when authenticating to ThingWorx Platform with Single Sign-On (SSO) enabled
Now we upgraded in our DTA to 9.6.1 , with LDAP all works fine, when we test with SSO then the application returns the HOME URL in HTTP://Thingworx/Runtime/index.html?mashup=MSU.Mainmashup=MSU.Main and lands in a Loop to go to a https url,  Where 9.5.1 returns the URL Relative like this
 //Thingworx/Runtime/index.html?mashup=MSU.Main. Does anyone has an idea?
TonyZhangAnswer
Support
Feb 12, 2025 9:39 AM UTC
The support case is closed with the resolution article being https://www.ptc.com/en/support/article/CS434659
Seems to be a configuration issue when TWX is behind a reverse proxy (Nginx in this case).
@EM_10066743 Welcome to add more details on the root cause and resolution if you would like. Thanks.
Support
Nov 28, 2024 7:47 AM UTC
Hi @EM_10066743,
Could you please elaborate on the issue you are facing? It'd be ideal if you could provide some screenshots to demonstrate the issue replication steps.
Also, could you please provide your sso-settings.json and idp metadata?
Nov 28, 2024 8:36 AM UTC
root@f24dce9dd7f4:/ThingworxPlatform/ssoSecurityConfig# cat sso-settings.json
"BasicSettings": {
"clientBaseUrl": "https://xxx.xxx.nl/Thingworx",
"idpMetadataFilePath": "/ThingworxPlatform/ssoSecurityConfig/sso-idp-metadata.xml",
"metadataEntityId": "xxx-Thingworx-xxx",
"metadataEntityBaseUrl": "https://xxx.xxx.nl/Thingworx",
"webSSOProfileConsumerResponseSkew": "300",
"webSSOProfileConsumerReleaseDOM": "true",
"webSSOProfileResponseSkew": "300",
"retriggerOnScopesRemoval": "true",
"samlAssertionUserNameAttributeName": "uid",
"samlAssertionMaxAuthenticationAge": "77760000"
"ApplicationKeySettings": {
"enabled": true
"SAMLContextProviderSettings": {
"scheme": "HTTPS",
"serverName": "xxx.xxx.nl",
"serverPort": "443",
"includeServerPortInRequestURL": "false",
"contextPath": "/Thingworx"
"AccessTokenPersistenceSettings": {
"dbType": "postgres",
"driverClassName": "org.postgresql.Driver",
"url": "jdbc:postgresql://postgresql:5432/thingworx",
"username": "thingworx",
"password": "xrowgniht",
"encryptTokenInDatabase": "false",
"keyczarKeyFolderPath": "/ThingworxPlatform/ssoSecurityConfig/symmetric/"
"KeyManagerSettings": {
"keyStoreFilePath": "/ThingworxPlatform/ssoSecurityConfig/sso-keystore.jks",
"keyStoreStorePass": "thingworx",
"keyStoreKey": "thingworx",
"keyStoreKeyPass": "thingworx"
"AuthorizationServersSettings": {
"AzureSSO-1": {
"clientId": "f2b1bfd4-61a6-4e5d-a10e-xxxx",
"clientSecret": "8eb8Q~zZ6behnxxxx~fTLwWGpHLSv_xxx",
"authorizeUri": "https://login.microsoftonline.com/339333e1-b5c5-410a-8b9e-xxx/oauth2/v2.0/authorize",
"tokenUri": "https://login.microsoftonline.com/339333e1-b5c5-410a-8b9e-xxx/oauth2/v2.0/token",
"clientAuthScheme": "form"
Nov 28, 2024 8:54 AM UTC
Hi Tony, Thank you for your reply, hereby some additional information.
