use of GetServiceDefinitions for uncategorized services
with the service:
result = Things[thingName].GetServiceDefinitions({
    category: category /* STRING */, ,
    type: undefined /* BASETYPENAME */, ,
    dataShape: undefined /* DATASHAPENAME */
i can get all servicedefinitons of services of a special category.
But which Sting do I need to use if i want to get all uncategoriezed services?
I've tried *Uncategoriezed*", "'Uncategoriezed*", "**Uncategoriezed**", " ", "", "uncategoriezed", "*uncategoriezed*", "**uncategoriezed**", nothing.
All of them are wrong.
Does anyone have any idea what the right string is?
We use thingworx 9.1.8 and 9.3.7.
Rocko
RockoAnswer
Assuming you know all the existing categories, here's what you can do: Query all services and subtract all the services returned by querying for all the categories. What's left over are the services without category. Not super-efficient, but it could work - under the assumption.
Hi @DJ_9605282
Try to use this:
let result = Things['Thing'].GetServiceDefinitions({
category: undefined /* STRING */,
where category is undefined, you should get all services that do not have a category.
Thanks for your reply,
Unfortunately, I tried this and as a result I get all the services, with or without a category.
What if you keep call like this, but then sort result by category == null / undefined? Maybe this is not direct method, but hope it will work?
Rocko
Here's a slightly more elegant solution giving you an array of uncategorized services defined on the current thing:
let entityDef = Resources["EntityServices"].ReadEntityDefinitionAsJSON({name:"YourThingName", type:"Things"});
let sDefs=entityDef.effectiveShape.serviceDefinitions;
let services=Object.keys(sDefs).filter(s=> !sDefs[s].category && !sDefs[s].sourceName);
Thank you, thats the very good solution.
